graememk
| posted on 1/3/06 at 08:37 PM |
wrong steering wheel or boss ?
Please help, I’m away from home at the moment so it’s a good time to do some problem solving, but that’s hard work so thought I’d do a bit of thinking
about the kit.
I bought a steering wheel (mountney) and boss from a mate that has a caterham (zzzzz), it didn’t fit as the boss was wrong, I bought a ford boss that
fits the mk but now the boss is much smaller them the wheel, is there any other conversion I can buy or do I need a different wheel or a different
boss?
Liam
| posted on 1/3/06 at 08:53 PM |
That's odd - Caterham normally use the smaller 3-bolt on 50mm PCD pattern for their steering wheels, so your Caterham wheel would be
'smaller' than an aftermarket boss which is commonly the 6-bolt on 70mm PCD? Or is that what you mean?
Well that's what happened to me - I bought a Caterham wheel and boss which were both the smaller 3-bolt pcd. I then got a Momo ford fitting
boss which is 6-bolt 70mm PCD and simply redrilled the steering wheel to fit.
Does that help? If your problem is really the other way round, i.e. you have a steering wheel with 6-bolt 70mm PCD and a 3-bolt 50mm PCD boss, then
you might just want to get another boss. That's assuming you cant just drill your wheel for the smaller PCD (cos maybe it has a big hole in the
middle). The advantage of a big 6-bolt aftermarket boss is that they keep the indicator cancelling, horn button, and collapsibility. The small
3-bolt fitting stuff is for race cars normally and dont tend to keep those features - it's just a lump of metal.
LIam
[Edited on 1/3/06 by Liam]
graememk
| posted on 1/3/06 at 08:55 PM |
to clarify, the boss will go through the hole in the wheel..... ie the hole in the wheel is bigger than the boss. or the boss is to small for the
hole.
Mark Allanson
| posted on 1/3/06 at 08:57 PM |
I had a mountney boss, the casting quality was so poor that the steering lock wouldn't work, the pawl just skitted over the slots.
I cut open my original sierra wheel and removed the boss and welded up a colapsable section to attach to the wheel.
graememk
| posted on 1/3/06 at 09:04 PM |
bugger i threw the old ford wheel away.... arghghgh
Liam
| posted on 1/3/06 at 09:07 PM |
So you got the little race style boss and a big 6-bolt wheel then. In that case you either need a new boss (often come up on ebay) or an adaptor like
this...
Rally design adaptor
Personally i'd get a replacement boss so it's collapsable and has the horn and indicator cancelling in it, but up to you...
Liam
graememk
| posted on 1/3/06 at 09:39 PM |
ok so wheres the best place to buy a boss from for my mountney wheel ?
would be good if steering lock and indicators worked ok
Mark Allanson
| posted on 1/3/06 at 09:54 PM |
I searched everwhere for something that I thought would pass the SVA, but without result, thats why I spent 6 hours designing, welding, fettling my
own! It passed the SVA, looks great.
See the difference in quality between ford and the other!
graememk
| posted on 1/3/06 at 09:58 PM |
ok so whos going to sell me an old ford wheel then, please pritty please
eddymcclements
| posted on 1/3/06 at 10:31 PM |
Post some photos of what you've got (when you're back at home) and I'll see what I have to suit.
As I understand it, the Caterham upper column is, or used to be, an Allegro part with a spline while the Sierra uses a large hex end. I may have an
old Sierra wheel centre and I'll definitely have a 6-bolt hub for the Sierra column becoming spare in a few days time when I change my column.
This hub has two sets of mounting holes to fit both of the common 6-bolt PCDs.
Eddy
Liam
| posted on 1/3/06 at 11:07 PM |
I have a sierra wheel centre already removed from the wheel and turned down. I was making my own boss a bit like Mark when i picked up my Momo one
cheap and saved myself the hassle. You can have it if you want. The quality of my Momo boss is fine, by the way.
Liam
| posted on 2/3/06 at 02:11 PM |
We had a Mountney boss and had to return it as the quality was so poor - similar to what has been described. For £2 more the MOMO one is far superior
and fit great.
S
