the_fbi
| posted on 8/3/06 at 07:34 PM |
3 connections on fuel tank? What for?
I may be having a dumb moment, but I can't work out what the low front connection is on this tank.
Top right is fuel return
Bottom right is outlet to pump/engine etc.
Middle front??
Regards
Chris
the_fbi
| posted on 8/3/06 at 07:36 PM |
Or is top right a vent and the return is the middle front and it needs a one way valve?
Bit awkward running uphill for the return at the top of the tank, but having it below the "waterline" will be awkward too, unless there is
a oneway valve fitted.
Deckman001
| posted on 8/3/06 at 07:44 PM |
You might need to shine a torch through that bigger hole you have in the top of the tank, and see where the different pipes go to inside ?? top on
mine is a vent, lowest is from a swirl pot and is the feed to engine, another lower one is the return from an injection system or bypass.
Hope this helps
Jason
the_fbi
| posted on 8/3/06 at 07:58 PM |
Thanks Jason I'll take a look.
I'm pretty sure they are just bosses with no internal pipes, but I'll check to make sure.
ta
Chris
Deckman001
| posted on 8/3/06 at 08:08 PM |
If your lucky , the holes will be undrilled, then you just drill the ones you need
Jason
