barraw
| posted on 9/3/06 at 10:08 PM |
cortina/escort upright identification
Hello, I'm wanting to buy some nice new 4 pot calipers, but I don't know which uprights are fitted to my 1990 westfield. Can anyone tell
me how to tell?
thanks
[img]C:\Documents and Settings\barraw\My Documents\My Pictures\dsc02490.jpg[/img]
[Edited on 9/3/06 by barraw]
Stu16v
| posted on 9/3/06 at 10:20 PM |
*Probably* Cortina for a Westfield of that vintage.
Westfield also supply fabricate uprights, but unles your car has been 'upgraded' it will more than likely have 'Tina uprights
dave-69isit
posted on 9/3/06 at 10:26 PM |
brakes upgrade
a piture would help
barraw
| posted on 9/3/06 at 10:29 PM |
I'm having difficulty adding a photo - will keep trying
flak monkey
| posted on 9/3/06 at 10:36 PM |
The calipers to fit Mk2 escort and cortina uprights are identical anyway *they both originally used the M16 caliper.
Having said that the uprights are most likely cortina. If they are on double wishbones then they are definately cortina. Escorts used struts.
Sera
http://www.motosera.com
Deckman001
| posted on 9/3/06 at 10:37 PM |
Jolly good , another avenue for my hubs
Jason
barraw
| posted on 9/3/06 at 10:50 PM |
how much for the hubs Jason?
BurtonPower tell me that cortina uprights could take m12 or m16 calipers, depending on whether it's mk1/2 or later. mine has upper and lower
wishbones - but still haven't figured how to attach a photo
[img]C:\Documents and Settings\barraw\My Documents\My Pictures\DSC02490.JPG[/img]
barraw
| posted on 9/3/06 at 10:53 PM |
maybe this time - forgive my ignorance
miserableoldgit
| posted on 9/3/06 at 11:43 PM |
Definitely Cortina Uprights, same as mine on 1986 Pre-Lit.
M16 calipers which can be replaced by Stuart Taylor 4 pots (I got those, look and work really good) or Austin Princess 4 pot (rockin' horse
droppings now)
Youth and vitality are wasted on the young
Avoneer
Cortina.
M16 calipers.
Hi-Spec do bolt straight on calipers and Wilwoods will go on with an additional bracket.
Try raldes.co.uk for your Wilwoods and Hi-Spec direct for the Hi-Specs.
Hope that helps,
Pat...
Deckman001
| posted on 10/3/06 at 03:38 PM |
Hi ya, Mine have been made for fitting to MK3/4 or 5 cortina uprights, and are a straight swap, saving 1Kg per hub
The price is £131 Delivered, Including Fitted bearings (Timken)
Hope this helps
Jason
