poprodder
| posted on 12/3/06 at 05:36 PM |
steering coupling.
hi,
fiesta steering rack, other than fiesta,what other couplings an joints fit it?
cheers chris.
Mark Allanson
| posted on 12/3/06 at 07:58 PM |
If you are thinking of using a Fiesta rack on an Avon you will be in for a bit of a shock when you come to drive it!
The Fiesta rack is originally set behind the axle line and the Cortina uprights use a rack set ahead of the axle line, so your right hand movement of
the wheel would produce a left turn in the car, Ok once you had got used to it I suppose
poprodder
| posted on 22/3/06 at 06:44 PM |
cheers mark.
thought things were too good when i bought recon rack for a tenner!!!
i guess if they were any use everyone would be buying them and pushin the price up.
chris.
