Mark Allanson
posted on 17/3/03 at 07:36 PM |
19mm radiuses (ii?), where do they apply?
Got the week off work, really attacking the car to catch up, I put in the steering today, and just finished. I used 13mm ERW round tube to mount the
upper column, but now remember that you have to have radii of more than 19mm - does this appy just to the dash or anything behind it?
Viper
| posted on 17/3/03 at 07:42 PM |
i believe the 19mm rad is along the bottom edge of the dash, so the whole width of the dash..
Mark Allanson
| posted on 17/3/03 at 08:35 PM |
Does it apply behind the dash?
Viper
| posted on 17/3/03 at 08:41 PM |
the way i read it is the bottom edge of the dash, if the half sphere comes into contact then it should be radiused.
chrisg
| posted on 17/3/03 at 08:54 PM |
Thet don't check behind the dash and anything behind the steering wheel is exempt - don't worry you're fine!!
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Mark Allanson
| posted on 17/3/03 at 09:08 PM |
thanks both, what do you think of the mount?
Viper
| posted on 17/3/03 at 09:11 PM |
Very neat,,,
chrisg
| posted on 17/3/03 at 10:30 PM |
Looks good Mate, beats the chewing gum and piece of hairy string I used!
Chris
| posted on 18/3/03 at 08:36 AM |
One comment on the mount - looks very neat, but watch that you don't have the same problem that I had...
Sit in the car, grab the wheel with both hands, and try to move the wheel and column side to side. If there's a noticeable waggle, then you might
consider a diagonal brace (mine's cross-braced to the scuttle wall and pedal box).
regards,
James
| posted on 18/3/03 at 10:30 AM |
Mark, I'm a little concerned: I know you lost your barn but looking at this picture you appear to be building at sea? Is your chassis currently
balanced on top of a small rowing boat? Do the waves/wash not make welding a little hard? And how did you get a surface flat enough to get your
chassis straight?
Or, is it really the case that you've been lying to us all along and you're really building a Pinto powered boat?
Concerned,
James
Dave Ashurst
| posted on 18/3/03 at 04:25 PM |
They checked thoroughly behind the dash at my SVA a year ago.... but then they were checking for min 2.5mm radii (as I recall) on internal projections
into the footwell area. I had to put plastic covers over the nuts inside the scuttle for the windscreen support bolts.
19mm radius applied only to the bottom edge of the dash.
I doubt anyone could be sure how they would interpret the rules for the legs of your nice column support structure if they were exposed below the
bottom of the dash.
suggest phone them perhaps?
regards
Dave
Mark Allanson
| posted on 18/3/03 at 09:35 PM |
David,
I got the mount 3mm out on first tacks, I put me portapower on it and the 500kg spreader would not budge it, I had to cut out and re weld - I woul be
happy lifting the whole car on the mounts
James,
It's ok unless the swell gets above 6 foot, look at my avatar, i am only 1/2 mile away from the mount!
Dave,
the support is made of 13mm round EWR tube so should be ok on the 2.5mm rule, but I will look out for the rest of the stuff I bung under the
scuttle
Thanks everyone
Mark
