Author: Subject: Ford boot kit help
Wadders
posted on 19/3/06 at 02:16 PM Reply With Quote
Ford boot kit help
Help, i need a pair of tripode boot kits, without a year or model to quote, the dealer is hopeless. They grudginly showed me three different versions on the micro fiche so i took pot luck, and yes you guessed it they were wrong, and non returnable cos they had to order em from the factory.
Part number i bought is 83BX 4K258 AB, these are too small and must be for drum braked sierras with the smaller diameter shafts. I need a pair for bigger diameter shafts which i guess must be disk braked.
Any ideas on part numbers etc would be cool.
TIA
Alan.
fesycresy
posted on 19/3/06 at 03:29 PM Reply With Quote
Tried your local motor factors ?
Wadders
posted on 19/3/06 at 03:33 PM Reply With Quote
No, but i doubt they would stock them, its not just a rubber boot, it includes the metal shroud for the tripode, which i suspect will be a dealer only part. Even my local ford dealer had to special order them.
posted on 19/3/06 at 03:52 PM Reply With Quote
Pretty sure most big motor factors will have them.
