Author: Subject: Sierra Uprights
darrens
posted on 4/4/06 at 06:02 PM Reply With Quote
Sierra Uprights
Does anyone know what size bolt goes through the top (which used to hold the Mcpherson strut), lost mine.
Howlor
posted on 4/4/06 at 06:31 PM Reply With Quote
M12 I believe although I'll check for you.
andyw7de
posted on 4/4/06 at 07:15 PM Reply With Quote
It is M12 although not sure what length cos my cycle wing brackets fit onto the end so mine are 100mm long
cheers
tks
posted on 5/4/06 at 12:46 PM Reply With Quote
=HIJACK ON
Can anyone of you 2 telle me ribs the abs ring has on that hub please??
DarrenW
posted on 5/4/06 at 03:37 PM Reply With Quote
darrens - is that the bolt that you will use to hold the mushroom adaptor instead of the strut? If so mine seized so i drilled out (clearance) and replaced with long high tensile M12 nut and bolt that also secures cycle wing bracket..
[Edited on 5/4/06 by DarrenW]
