Dutchman
| posted on 5/4/06 at 12:11 PM |
Uprights proposal
found these uprights
  uprights 1
  uprights 2
  uprights 3
these bolts are just for takeing a pic...
I think to go with these ... but uper whish bone should be simetrical because the uper and down hole for ball joint are in line...
any sugestion ... should I make some adaptor the distance from up to down ball joint mounting position is 145mm (5.7in)
Tarzan English with foreign accent!
theconrodkid
| posted on 5/4/06 at 12:16 PM |
look like lada parts?,ask alfasudsprint,he is using lada running gear
who cares who wins
pass the pork pies
Mad Dave
| posted on 5/4/06 at 12:41 PM |
You still need to create some caster angle!
Dutchman
| posted on 5/4/06 at 12:45 PM |
Yes it is lada parts ... very cheap and can be bought new from the shop
??? what is the castor angle ... I was thinking to use book chassis mounting points for whishbones...
nitram38
| posted on 5/4/06 at 01:27 PM |
Most racecars run 3 degress, production 5-6 degrees. 5 is probably about right
| posted on 5/4/06 at 04:34 PM |
The way they are bolted together is for rear streer -- swapping the arms over side to side should fix this however the steering arms look very long
compared to Cortina units.
Might be best to fabricate new steering arms and use rose joints (sperical rod end bearings).
Lippoman
| posted on 6/4/06 at 05:59 AM |
Does anyone have the dimensions and weight for the Lada uprights?
They are dirt cheap, and the modular build should make it "simple" to alter brakes, steering arm, etc.
Cousin Cleotis
| posted on 6/4/06 at 12:29 PM |
Fiat vented disks fit the lada hubs without any mods, just need adapters for calipers, and calipers.
i dont know why no kit cars used ladas as a donor, wishbone front suspension, 5 linked live axle, tuneable engine.
thousands of possible donors have been crushed, a riva would have cost about the same as pair of cortina uprights.
My lada, 8000miles from new, stored last 14 years, 500 mile round trip the same week i put it on the road.
Paul
[Edited on 6/4/06 by Cousin Cleotis]
Dutchman
| posted on 7/4/06 at 01:59 PM |
I will make a drawing with all measurements or something like that tonight ...
found the blueprints of Cortina uprights so I think that I will start making whishbones from monday on ...
One more question from witch car do U use metalistic bush ... so far the smalest one that I found is from Renault 5 (diametar 32mm, hole 12mm and 36mm
in lenght)
Marcus
| posted on 7/4/06 at 03:47 PM |
Metalastic bushes from Triumph Spitfire or Herald.
Marcus
Marcus
Because kits are for girls!!
Dutchman
| posted on 10/4/06 at 08:59 AM |
  lada uprights
the balljoint is 17mm conus hole
NS Dev
| posted on 10/4/06 at 11:28 AM |
in lenght)
In your country I would say use whatever you can find that looks right. Certainly the Renault one sounds like it will do the trick.
Obviously you will have to make the suspension components to fit whatever bush you use, but there's no need to use the triumph bushes, most UK
builders don't use them anyway now, most use polyurethane bushes similar in size to your renault ones.
Dutchman
| posted on 11/4/06 at 10:43 AM |
Yes I already order a pipe section to be done on lathe for that metalistic bush .. I tought about poly bush , but I'm making a car for road so
rubber is more flexible and soft ... if ever the racing series start here we will change...
new question ....
can rose joint replace the uper ball joint ... of course with some adaptor ect. , I mean in sense of strenght and durability.
