welshy
| posted on 26/3/03 at 02:53 PM |
Sierra Hubs??????
To the panel of Knowledge,
I am using the front Hubs off of a sierra and I was wondering what lower ball joints I can use as I don't want to use the track control arms
like the Avon Tiger does. Will the bottom swivels from a MKIII, IV, V Cortina or maxi do?
Welshy
[Edited on 26/3/03 by welshy]
Simon
| posted on 26/3/03 at 03:09 PM |
Welshy,
Contact Luego - I'm using Sierra front uprights, with their wishbones.
They supplied me with the upright adaptors (which you'll also need) and the balljoints.
They should be able to help.
Simon
James
| posted on 26/3/03 at 03:55 PM |
quote: Will the bottom swivels from a MKIII, IV, V Cortina or maxi do?
Welshy
Hi Welshy,
Yes, if you get the bottom ball-joint hole on the hub bored out to fit the hub- it needs to be the correct taper as the standard one is too small. See
link for taper dimensions:
http://forum.locostbuilders.co.uk/xmb/viewthread.php?tid=3808
MK will bore the hub out for you on an exchange basis of £7 per side.
You probably know this but just in case: the wishbones need to be relatively different lengths compared to using the Cortina hubs.
HTH,
James
[Edited on 26/3/03 by James]
Viper
| posted on 26/3/03 at 05:51 PM |
Welshy
Track control arms ???what track control arms???
welshy
| posted on 27/3/03 at 11:24 AM |
Cheers Lads for all the help.
I will contact MK if i can't some one to bore them out at work for me.
And James, I am going to work out how long the new front wishbones have to be. If you are using the Mcsorley 7+4+4 chassis can you please let me know
what dimensions you got, so i can check mine against them.
| posted on 27/3/03 at 11:33 AM |
It's the arm between the chassis and the bottom of the hub. It comprises the bottom balljoint and the compliance bush for the anti-roll bar. It
gets called lots of different names, especially when the bushes need changing.
yours, Pete.
Viper
| posted on 27/3/03 at 05:18 PM |
yours, Pete.
I know what they are i was just wondering where they are on an avon?
| posted on 27/3/03 at 08:07 PM |
I've only seen them used on Robin Hoods old sliding pillar system front suspension, he probably meant them. Don't Avons use wishbones same
as "normal" locosts?.
James
| posted on 28/3/03 at 11:54 AM |
Hi Wleshy,
I'm not using anyone else plans other than those of my good self! Which probably explains why it's taking so damn long!
Saying that though- my chassis is setup to be able to take standard sized wishbones if I want- that also gives me the option of buying MK ones if I
want though.
James
