Author: Subject: is this right
omega0684
posted on 15/4/06 at 06:15 PM Reply With Quote
is this right
HAPPY EASTER EVERYBODY!
i hope you are all having a good easter? im not, as i have a suspension problem, can you guys take a look at these photos and tell me whether or not i have put this together properly, im a little confused as the build manual is a little confusing and worded i little mind bogglingly
im not too sure whether the top wish bone is on the right way round, can someone clarify for me. i also need to know the torque of the nyclon nut that is on the inside of the cycle wing bracket, that bolts to the upper wishbone ball joint?
thanks all
Alex
omega0684
posted on 15/4/06 at 06:21 PM Reply With Quote
i thought so, do the longer arms go towards the front?
Fozzie
posted on 15/4/06 at 06:25 PM Reply With Quote
Yes, the longer arms to the front!
omega0684
posted on 15/4/06 at 06:46 PM Reply With Quote
do you mean like this? if this way is right, isnt the front long bar of the wish bone a little close to the springs?
Alex
p.s very quick wishbone change
DIY Si
posted on 15/4/06 at 07:20 PM Reply With Quote
That looks about right for the castor, which is wy they were wrong before. They should be ok like that, assuming dax's usual good build quality. Glad to see you're getting on with it. When are you hoping to sva?
Fozzie
posted on 15/4/06 at 07:26 PM Reply With Quote
Originally posted by chris mason
that looks better Alex, it shouldn't catch the spring though as the wishbone will rise once the car is lowered to the ground.
i'd check with a dax owner though just too be sure.
Chris
Yup, seconded!
omega0684
posted on 15/4/06 at 07:34 PM Reply With Quote
hi Si, hoping to SVA towards the end of the summer, FINGERS CROSSED X X X
DIY Si
posted on 15/4/06 at 07:37 PM Reply With Quote
You'll have to take me out in it then! Give you a chance to show off all that expensive dax gear you've got! I'll return the favour once mine's built. One day in the distant mists of time......
omega0684
posted on 15/4/06 at 07:48 PM Reply With Quote
is the mrs' still giving you stick about the car then its great being single, all my spare time to the car lol
DIY Si
posted on 15/4/06 at 07:50 PM Reply With Quote
Not too bad, but yeah! Only been allowed out to play 1 day in the past 4 weeks!
omega0684
posted on 15/4/06 at 09:56 PM Reply With Quote
major bummer there SI, i.ve managed to coup up about 4-5 hours a day, most of my time has been on trimming the body panels and filing but its coming on bit by bit
