Author: Subject: hydraulic brake switch
locoboy
posted on 18/4/06 at 09:44 AM Reply With Quote
I have just bought a 4 way piece to incorporate the standard T joint in at the rear of my car and the hydraulic brake switch.
The 4 way is standard m10 thread but the switch has a tapered thread and will wind in for the first 2 turns ok but then becomes stiff.
can anyone tell me what switch i need to fit in my non tapered 4 way joint?
Locoboy
stevec
posted on 18/4/06 at 10:30 AM Reply With Quote
I think you will find what you have is correct.It is supposed to become stiff, Thats what seals the joint.
All the best.
locoboy
posted on 18/4/06 at 10:32 AM Reply With Quote
Does it not seal in the conventional manner by pressing against the machined seal seat in the 4 way joint - like the ends of conventional brake pipes do?
This way its just sealing on the threads only isn't it?
Locoboy
stevec
posted on 18/4/06 at 10:48 AM Reply With Quote
Yes Scarey isnt it, It does work though,Just tighten it holding the 4 way fitting firmly and check it for leakage by firm pressure on the brake pedal.
posted on 18/4/06 at 10:56 AM Reply With Quote
Sounds more like an oil pressure switch with a 1/8" NPT thread.
NS Dev
posted on 18/4/06 at 11:00 AM Reply With Quote
mine's the same, works just fine, don't worry.
A lot of the ally 4 pot brake calipers come with taper thread fittings
stevec
posted on 18/4/06 at 12:18 PM Reply With Quote
Forgot to say mine is the same and all parts were supplied by MK.
Steve.
locoboy
posted on 18/4/06 at 01:38 PM Reply With Quote
full steam ahead then!
Thanks lads
Locoboy
James
posted on 18/4/06 at 02:19 PM Reply With Quote
Mine's the same.
On the recommendation of others here I wrapped some PTFE tape around the threads just to be sure!
James
Surrey Dave
posted on 18/4/06 at 04:47 PM Reply With Quote
Just fitted a new switch it did not have a tapered thread , it was 10mm x 1.0 (metric fine) made by Intermotor and came from 'Car Builder Solutions'
