caber
posted on 19/4/06 at 08:53 PM |
Studs with Nuts!
Ok what length studs do I need for the standard 4 spoke Laser alloys on the capri back axle and front cortina hubs? Do I need special/ different nuts
for these alloys and steels i will be using to hold my car off the ground during the build?
Finally where is best to get these studs and nuts? I mean in stock and cheap not like my local motor factors!
TIA
Caber
Avoneer
| posted on 19/4/06 at 09:52 PM |
The only studs I have found to fit the wheels are standard Mk2 Escort ones.
Nobody and I mean nobody makes new ones that have such a short shoulder to enable the conical nut to tighten up fully against the wheel - unless the
seatings for the bolts in your wheels are the flat ones - if that's the case - use Sierra wheels studs all round.
Hope that helps,
Pat...
RazMan
Rally Design do a whole load of studs & nuts. Generally speaking you will need 5-6 full turns of the nut to ensure security, so figure out the
length by offering up your alloys and measuring the amount of thread that protrudes.
Raz
| posted on 19/4/06 at 11:09 PM |
The Capri axle studs should be alright to fit them to, that's what they came off isn't it? I haven't tried mine on the cortina studs
but I can't see any problem fitting them. The studs don't need to protrude as the nut goes into the taper on the rimThere are usually some
on
ebay
