smart51
| posted on 3/5/06 at 09:37 AM |
XR4x4 drive shaft question
How do you know if you have a matched pair of drive shafts? Are they the same length or is one longer than the other?
[Edited on 3-5-2006 by smart51]
mackei23b
| posted on 3/5/06 at 10:00 AM |
Hi there
Yes, one should be longer than the other
Ian
Cheffy
| posted on 3/5/06 at 12:39 PM |
I've got XR4x4 drive shafts. If you put the shafts on a flat surface and measure between the outer face of the flanges with the faces parallel
to each other and at 90 degrees to the drive shaft itself, one shaft will be about 49cm and the other about 47cm.
At least - mine are!!!
Hope that helps
Mart.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
