ditchlewis
| posted on 5/5/06 at 11:13 AM |
Any one got any old valve springs???
As it says realy, i need some old Valve springs to put in my steering rack to give me some self centring on the steering.
i would be greatful for any help
regards
Ditch
zxrlocost
| posted on 5/5/06 at 11:21 AM |
valve springs dont work
Ive tried them they make it work on the spot but not when drivingIve even doubled them up
ned
| posted on 5/5/06 at 11:25 AM |
done the tyre pressures a tow settings yet?
beware, I've got yellow skin
MikeR
| posted on 5/5/06 at 11:27 AM |
does this work? is it not dangerous adding stuff to a rack, what if it comes lose / breaks - you'd lose steering!
(if it works, can i have some too? )
NS Dev
| posted on 5/5/06 at 11:31 AM |
you don't need em Mike, I'll call you later about a load of stuff incl that.
I'll be making some jose rointed upper bones, tigged obviously in the not too distant future with the caster setup of your choice!!
zxrlocost
| posted on 5/5/06 at 11:33 AM |
no its not dangerous
nothing can come loose you put them inbetween the mushroom collar and internal part of rackie under the rubber covers
but Valve springs dont work(only on the spot) unless you have to adjust a few other things aswell
can anyone reccomend a harder spring
| posted on 5/5/06 at 11:52 AM |
Pre-SVA toe out - the tyres squeal but it centres... correct after SVA.
greggors84
I would be up for some of them! I'm guessing although rose jointed they would still be able to be used with the standard mounts?
Chris
The Magnificent 7!
MikeR
| posted on 5/5/06 at 12:32 PM |
Nat, i'll set up the website, get registered as a trader on here, take orders, deal with money, you make the stuff ..... Think i could organise
supply or GRP as well. perhaps we could make our own cars.
what should we call your business, Manyana? Can't use NSD - too similar to a well known VX company
(editted to add, i am joking before people try and place orders with me)
[Edited on 5/5/06 by MikeR]
ditchlewis
| posted on 10/5/06 at 09:08 AM |
many thanks, i will try the local garage as he seens to always be working on sports cars and see if he can set up my suspension properly first.
if still no joy then i will try the springs
ditch
| posted on 10/5/06 at 10:19 PM |
I sure someone mentioned that SVA centers have cottoned onto this one and will fail cars for excessive toe out?
