| posted on 8/5/06 at 08:16 AM |
Sierra Wheel Studs
Looking to buy some longer Sierra wheel studs to replace the existing ones.
Image deleted by owner
Does anybody know how long the standard ones are?
The choices for longer ones are
1 - Standard plus 13mm 47mm long 12mm 1.5 Ford
2 - Standard plus 25mm 63mm long 12mm 1.5 Ford
I thought the standard Sierra ones were 40mm long but looking at the above dimensions it would appear that standard is 34mm or 38mm. Or am I reading
it wrong? Which ones do we need, I'm confused...............help!!
Phil
ReMan
| posted on 8/5/06 at 08:29 AM |
Just measured mine that I took out and replaced, they are 45 mm and 42mm.
Dont know which way round but they ar from a 4x4 back end with alloys and a 2wd front unknown origin (MK).
That measured end to end including the flange whic is 4-5mm.
HTH
Colin
I suppose 42mm - 4 mm =38mm, so that would figure.
BTW I ended up getting very oversize and shortening them to suit.
[Edited on 8/5/06 by ReMan]
| posted on 8/5/06 at 08:40 AM |
istr Ford changed the wheel stud length on the Sierra in the mid 80s
| posted on 8/5/06 at 09:07 AM |
That would explain it. Cheers guys.
