pointy
| posted on 9/5/06 at 05:15 PM |
HElp help help help
Just had an m.o.t on my velocity and it failed on steering rack>>>not too bad...however I have found some one to set up tracking and camber
so question is what should the camber be set at?
andy P
piddy
| posted on 9/5/06 at 05:37 PM |
Hi.
When you say it failed on the steering rack, do you mean the way the tracking and camber are set or the rack itself?
pointy
| posted on 9/5/06 at 06:31 PM |
The rack had excessive play. but the new rack once fitted will be set up including the camber hence the question.
piddy
| posted on 9/5/06 at 06:55 PM |
As copied from the Luego build manual
You will now need to make initial adjustments to the following:
Tracking – front
0.5–1mm toe-in
This is difficult to set accurately without the proper equipment
Adjust both sides to maintain equal O/S & N/S track rod lengths
Camber angle, front & rear
0.5–1.0 degrees negative, i.e. wheel leans in at the top
Can be set using a spirit level against the wheel rim, with spacing blocks to clear the tyre.
Castor angle, front
2-3 degrees negative, i.e. top of the hub leans back
Helps the steering to self-centre
This is difficult to set accurately without the proper equipment.
Adjust by rotating the aluminium mushroom in the top of the hub.
Ride height and damping rates – front & rear
Moving the adjustable collar on the shocks will raise and lower the ride height. Set all four corners of the vehicle to the same height.
Low damping rates allow the spring to move more freely - ideal for uneven surfaces
High damping rates restrict spring movement - ideal for the race-track.
ALL of the above will need to be professionally set/checked before road use.
pointy
| posted on 9/5/06 at 07:00 PM |
fantastic.
all adjustments being done on machine capable of all kinds of measurements.
Andy p
