paulbeyer
| posted on 10/4/03 at 10:43 AM |
Sierra Master Cylinder
I bought a sierra master cylinder at the Exeter kit car show last november and it is identical in every aspect to the one off my donor except for a
4th connection on the underside right at the front. I didn't notice this until I got home but decided to fit a bleed nipple to blank it off.
Trouble is I just found out it is an M12 size hole and I cant find a bleed nipple big enough (M10 is the biggest I can find). Does anyone have an idea
on how to blank this off and what it was intended for in the first place?
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
theconrodkid
| posted on 10/4/03 at 05:49 PM |
they were made different sizes to stop mongs on the line piping up wrong,can you use that hole and blank an m10?ill have a look in my box o bits and
see if i have 1
who cares who wins
pass the pork pies
paulbeyer
| posted on 10/4/03 at 07:51 PM |
ny reason why there would be 4 connections, three the same size and one like a bucket? If the big one was plumbed into the back brakes for example
what are you supposed to do with the remaining 3? One to each front brake and a spare? It don't add up in my book.
bob
| posted on 10/4/03 at 09:09 PM |
PAUL
You could allways plumb your inline brake light switch in the spare
paulbeyer
| posted on 10/4/03 at 11:13 PM |
Oh cheers for that Wendy. Two problems though.......
1) It's already fitted to the rear of the chassis
2) It doesn't have an M12 thread. Hold on a minute though I could wrap the threads in PTFE tape just a couple of rolls should do it.
Cheers Bob, you chocolate tea pot.
theconrodkid
| posted on 11/4/03 at 03:31 PM |
paul,ive found a 12mm union but no 12mm bleed valves,you could block off a 10mm outlet with a nipple and use a 12 for the other,yours if you want it
who cares who wins
pass the pork pies
paulbeyer
| posted on 11/4/03 at 09:15 PM |
it
You Sir, are a gentleman, a scholar and an acrobat. See you at Stoneleigh.
bob
| posted on 11/4/03 at 09:30 PM |
so my idea would /could have worked then .
see you at stoneleigh
