RichieC
| posted on 13/5/06 at 04:48 PM |
Suspension Idiots Guide
Hi all,
Can anyone explain exactly how to set Castor and Camber etc on a 7 type car in terms of which items to adjust to correct it.
I have a vague idea but a thickies guide would be appreciated.
Thanks in advance
Richie
DIY Si
| posted on 13/5/06 at 04:55 PM |
Camber is adjusted by altering the effective length of either the top or bottom wishbone. This is normally done by turning in/out a ball joint, or
rose joints depending upon how your arms have been built. Castor is built in, unless you're arms are rose jointed. If they are, the castor if
adjusted by 'pointing' the arm forward or backwards by altering the joint on just one side.
bilbo
| posted on 13/5/06 at 05:28 PM |
A slight thread hijack, but on the same topic: Is there an easy DIY way of measuring toe in/out? Probably a dumb question
DIY Si
| posted on 13/5/06 at 05:31 PM |
bits of string and a big ruler. And a calculator.
alister667
| posted on 14/5/06 at 12:05 AM |
bit of explanation of what I did HERE
Good Luck
Ali
PS I used a digital spirit level (bought from Lidl) to set up the camber, worked very well. About 2 degrees on each side on the front if I remember
correctly.
http://members.lycos.co.uk/alister667/
