Author: Subject: Removing seized diff plug
givemethebighammer
posted on 11/4/03 at 11:02 PM Reply With Quote
Any ideas on how to remove a knackered seized diff plug from a sierra diff ? Only I would like to top the oil up !!! Incidently what oil should I fill a sierra 3.62 LSD with ? It is being driven from a 2.0 L Zetec engine and type 9 gearbox.
Sparky
posted on 12/4/03 at 10:40 AM Reply With Quote
If I was in this situation, I think I'd find the largest nut in my spares box, one where the thread is just smaller than the outside diameter of the filler plug, and I'd weld through the nut onto the plug.
Two things happen here. You have much more leverage with a larger fastener, and the heat should be enough to break the seal. It does mean a new plug of course. (unless your welding's neat! )
As for the lubrication, I'm not sure. You mean you don't have a haynes manual?!
I'll have a look next time I'm in the garage.
givemethebighammer
posted on 12/4/03 at 11:53 AM Reply With Quote
Thanks I came to this conclusion myself. Haynes manual..yes however always good to get second opinion. What is good for a 2 tonne sierra is not always appropriate for a 600Kg seven !!!!
Wadders
posted on 12/4/03 at 05:53 PM Reply With Quote
iv'e used synthetic gear oil in mine,as its quite thin, only problem is the price £32 for 4 litres.
]Originally posted by givemethebighammer
givemethebighammer
posted on 12/4/03 at 07:16 PM Reply With Quote
Got the plug out by: drilling the knakered allen key socket out with a 12mm drill (not right through though), then cutting a M12 bolt to about 3cm and welding it into the hole I had just drilled. Very little effort was then required to remove the plug. Had to buy a new one though (£4.50 from Ford).
I think maybe the heat help a lot.
£32 for 4 litres yikes...
stephen_gusterson
posted on 12/4/03 at 11:43 PM Reply With Quote
the granada mk3 manual, using same diff, (haynes) specified std ep90 gear oil.
atb
steve
