Author: Subject: Rear Sierra calipers replacements
JoaoCaldeira
posted on 19/5/06 at 10:36 PM Reply With Quote
Hi again.
Are the "Hydra-Mechanical Ally Rear Handbrake Caliper" that Rally design sells direct replacement for rear Sierras's ones?
What other calipers can I use as direct replacement which are full SVA compiant (handbrake)?
Thanks in advance,
Joao
liam.mccaffrey
posted on 19/5/06 at 10:51 PM Reply With Quote
yes they are i have them
Build Blog
Build Photo Album
saigonij
posted on 20/5/06 at 06:43 AM Reply With Quote
are they a direct bolt on replacement?
what are the benefits of fitting them and what about the caliper carrier etc? can you use the original sierra carrier or do you have to search for the VW equiv?
liam.mccaffrey
posted on 20/5/06 at 08:03 AM Reply With Quote
the caliper bolts straight up to the sierra bearing carrier have not checked disc spacing yet.
the reason i bought them is that i didn't have sierra calipers the vw ones are meant to have a much more reliable handbrake mech, plus they're a bit lighter
Build Blog
Build Photo Album
