givemethebighammer
| posted on 14/4/03 at 07:57 PM |
Brake calipers and master cylinder repair or exchange ?
What do the rest you you people do, buy repair kits for brake parts (as I always used to) or just exchange your filthy old calipers and master
cylinders for nice clean exchange reconditioned units ?
Cost is the issue here, exchange caliper = £33, repair kit is £10. I changed the seals in umpteen mini wheel cylinders ten or so years ago and had no
problems.
eddymcclements
| posted on 15/4/03 at 08:29 AM |
I exchanged one rear caliper (Sierra) and kept the other as the donor had only just had a new one fitted before its owner stuck it in a ditch last
winter, but I rebuilt both fronts with a 10 quid rebuild kit.
You pays yer money...etc etc.
Eddy
givemethebighammer
| posted on 15/4/03 at 06:01 PM |
When you rebuilt the rear sierra caliper did you have the special tool (Ford Tool No. 12 007) detailed in the haynes manual to compress the adjust
spring ?
I think I will probably use repair kits throughout. Not had problems in the past with this method on both cars and motorbikes. I guess the exchange
units are only cleaned, refurbed old calipers anyway ? That is unless anyone wants to add any horror stories ...
Dick Axtell
| posted on 15/4/03 at 07:50 PM |
Master Cyls
Don't EVER try to re-work the modern (e.g. Sierra) mcyl. You'll never be able to replicate the factory tolerances on re-assembly. Buy new,
or factory rebuilt.
Alternatively, I just happen to have a spare Sierra mcyl. If you're going to Stoneleigh, I'll bring it along.
Dick
givemethebighammer
| posted on 15/4/03 at 09:09 PM |
does that go for calipers as well ?
jollygreengiant
| posted on 15/4/03 at 10:13 PM |
Calipers are remanufactured on an exchange basis to as new spec, so if youve got a suspect caliper for my money its not worth trying to fit new
seals.
Dick Axtell
| posted on 16/4/03 at 09:15 PM |
Calipers
Not necessarily. If you have the workshop facilities to remove the old pistons cleanly, and a suitable cleaning/degreasing rig, you could do it. I
fully re-worked my calipers in the caliper development shop (we used to make the bl**dy things!!).
