Author: Subject: Undoing hub nuts off car!
locoboy
posted on 21/5/06 at 02:46 PM Reply With Quote
I need to undo the rear hub nuts on the donor shafts but they are no longer attached to the Sierra!
Is it a case of penetrating oil, impact gun, heat if required, a large vice and socket and a large breaker bar?
Or are there any other ways?
Locoboy
need4speed
posted on 21/5/06 at 02:56 PM Reply With Quote
took mine to a friend with a 3/4 drive air gun soon came off. Don't forget n/s is left hand thread.
Dave.
SALAD
posted on 21/5/06 at 02:57 PM Reply With Quote
41mm socket on an impact gun is by far the easiest method I have found. Failing that a large bar does the job, or pop to the nearest garage if its easier.
jollygreengiant
posted on 21/5/06 at 05:06 PM Reply With Quote
Do mine with a large ( 3/4" ) breaker bar and a tyre lever in / through the studs.
[Edited on 21/5/06 by jollygreengiant]
posted on 22/5/06 at 04:36 PM Reply With Quote
I put mine in the vice and with a 1/2 metre ratchet and not great deal of force they came off without argument.
Iput them back together the same way!
