Tom Beattie
posted on 22/5/06 at 03:49 PM |
Castor Angle
What would be a reasonable castor angle to aim for on what will be essentially a road car, I want it responsive but not super twitchy. The book quotes
about 5.3 should it be abit more laid back? opinions please.
BKLOCO
| posted on 22/5/06 at 03:52 PM |
5.5 degrees is about right for caster angle these cars will never self centre particularly well due to the low weight on the front end.
Tom Beattie
| posted on 22/5/06 at 03:57 PM |
You'll see im new to this but reading this forum the consensus of opinion would appear to suggest an offset on top ball joint of 22-25mm using
sierra uprights, by my reckoning on a book chassis this gives castor of 7.69. however its a while since I've done any trigonometry so this could
be wrong. I'm just going to work out 5.5.
Tom Beattie
| posted on 22/5/06 at 03:58 PM |
Maybe I'm misunderstanding the offset measurement, is it top balljoint offset from centreline?
Tom Beattie
| posted on 22/5/06 at 04:00 PM |
If my trig is right then to achieve 5.5 you need offset of 17.8mm. Hows that sound?
russbost
| posted on 22/5/06 at 05:00 PM |
Most race car run about 3 -5 deg castor, road cars run anything up to 12. More castor means more self centreing. To check your calculatins are roughly
correct, you can use an adjustable spirit level, or a spirit level & a protractor.
BKLOCO
| posted on 22/5/06 at 05:20 PM |
The problem is the more caster you build in the heavier the steering becomes (amongst other things). This isn't a problem with power steering
but can be with manual steering and a small wheel.
907
| posted on 22/5/06 at 06:31 PM |
You can only speak as you find.
I have a light engine, set well back.
1mm toe in, slight neg camber, and 20psi.
My first bones, to the book, didn't centralize at all.
Remade them with 22mm offset, and now the car sort of starts to centralize.
At 45mph I can take my hands off the wheel, as long as I don't hit any bumps.
I think if I made a 3rd set I'd go 25mm, but like I said, light engine, well back.
Paul G
Bob C
| posted on 22/5/06 at 07:21 PM |
When I looked at this I decided uncle ron had made a error in his trig resulting in 50% the caster angle he was aiming for.
He built all the caster into the top wishbone. he made the balljoint to back distance 3/4" less than balljoint to front distance. And thought
his balljoint was 3/4" forward of the centre. It isn't - it's 3/8" forward of centre.
And henceforth a generation of locosts have had trouble self centring at SVA!
I expect the problem is made worse by the huge scrub radius of the cortina uprights
cheers
Bob
pucksaver
| posted on 22/5/06 at 07:34 PM |
More castor also means that as you turn the wheel the tires will gain more camber. Does this affect handling or anything?
russbost
| posted on 22/5/06 at 09:13 PM |
Yes, obviously, it's all a compromise between driveability & max performance, for SVA I'd have plenty of castor & v.little camber,
change it around afterwards.
| posted on 23/5/06 at 07:18 AM |
You have to remember that these cars are very light, so 7 or 8 degrees of castor still allows very easy steering.
My car has around 22mm of offset - it self-centres well enough, but still steers very well (VERY well!)
Tom Beattie
| posted on 23/5/06 at 07:40 AM |
Thanks folks, the more info and opinions I can get just now the less chance there is of me making an a**e of the car and myself at a later date.
| posted on 23/5/06 at 07:46 AM |
Yep steering on a Locost is never going to be heavy its is light and rear wheel drive --- in the days when men were men we drove cars weighing over 2
tons without power steering, even the largest trucks and buses only got power steering in the 1960s.
A Leyland Octopus -- power steering whats that ?
photo from http://www.daves-classic-transport.co.uk/
[Edited on 23/5/06 by britishtrident]
