| posted on 24/5/06 at 06:43 PM |
Driveshaft CV Joints
Can anyone tell me how this comes apart? looks different to other trilobe joints where you cut the cover off. Its all one solid machined lump.
HELP!!!!!!!!
DIY Si
| posted on 24/5/06 at 06:45 PM |
Is there a circlip or similar on the other end?
VanHaydn
| posted on 24/5/06 at 06:58 PM |
if its ford
it looks like its one machine solid piece but its not......
[Edited on 24/5/06 by VanHaydn]
t.j.
| posted on 24/5/06 at 07:28 PM |
Why want you take it apart?
Prob. to replace the cover. There are some joints that won't get apart. In that case it's better to take the otherside joint apart to
replace the covers.
| posted on 24/5/06 at 08:14 PM |
The circlip is inside behind the plastic disc I presume. The joint at the other end (wheel) is the same. It was miles bigger than teh brake back
plate.
The whole thing looks and sounds solid. I've used a file to see if there are any joins but cant see any.
All I want to do is replace the boots as they are perished and leaking.
Stuck big time!!
flak monkey
| posted on 24/5/06 at 08:19 PM |
Where the recess is about 1/3 of the way from the end of the joint. Thats actually a joint where the cover presses onto the joint itself. Well i think
it is. its probably rusted up so it looks solid. Have a scrape with a screwdriver.
Sera
http://www.motosera.com
| posted on 24/5/06 at 09:17 PM |
I'll try the electrolysis on it.
I've never seen one like this, all the others are flat across the top.
Will I be able to get the new metal sleeve for it OK? Any one else got them like this one??
Winston Todge
| posted on 25/5/06 at 09:46 PM |
If there is no play in the joint then, as you say just replace the boots...
A few different ways but this is what I did a couple of days ago...
http://cgi.ebay.co.uk/UNIVERSAL-CV-BOOT-DRIVE-SHAFT-GAITER-FITTING-CONES_W0QQitemZ8067136933QQcategoryZ30917QQcmdZViewItem
http://www.mytigeravon.co.uk/html/february_2003.html
Seems to be fine! 8D
Chris.
VanHaydn
| posted on 26/5/06 at 12:17 PM |
nice product
didnt know you get those ones nice.....very nice
bugger me there are some clever gits on this planet hey!
[Edited on 26/5/06 by VanHaydn]
