pauler
posted on 18/4/03 at 01:15 PM |
Can anyone explain how to set end float ?
Changing the crown wheel and pinion in my english rear axle but unsure how to set the end float ! Can this been done at home and how critical is it
paulf
posted on 18/4/03 at 05:06 PM |
I am playing with diffs at the moment and have a copy of a haynes manual for a mk1 escort. In this it shows how to set up a diff using engineers blue
to get the correct meshing.It would help to have a dial indicator to use to get the initial endfloat correct. Then it is a case of adjusting the screw
cups at each side of the crownwheel and if neccessary shiming the pinion .Ideally the pinion should be set up with a new compressable spacer to get
the correct bearing preload but they seem to be unavailabel, see the previous thread on this subject about a week ago.
Paul.
