Author: Subject: abs driveshafts
darrenga
posted on 4/6/06 at 11:27 AM Reply With Quote
abs driveshafts
my driveshafts have abs (teeth that go around the outside) will i have to remove the teeth,as it looks like they will catch the carriers
omega0684
posted on 4/6/06 at 11:37 AM Reply With Quote
i used the rear drive shafts off a 2wd cossie with abs, i had to take all the teeth off to get the stub axle through the de-dion brace, so if you are running de-dion then more than likely. bench grider do the trick a real treat, if you got one that is, it would take a very long time with a file
hope this helps
smart51
posted on 4/6/06 at 01:00 PM Reply With Quote
Mine just about fouled the rear uprights. I ground them down with an angle grinder until the grooves between the teeth jsut about disappeared. it seems to work fine.
darrenga
posted on 4/6/06 at 01:48 PM Reply With Quote
thanks. just ground mine of with angle grinder,now they fit great
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 4/6/06 at 02:39 PM Reply With Quote
Rear Stubs
While I was removing the ABS teeth I decided there was a lot of surplus material on the stub, so while I was at it I removed quite a lot of material from the stub.
I thought I had a picture but I can not find it.
John
