John
posted on 22/4/03 at 12:32 AM |
Metal Cowl Over Cortina Front Hubs
I have managed to get hold of a pair of the elusive Cortina front hubs. The brake disk is partially covered with a round sheet metal shroud as part
of the original setup. My question is how can this shroud be removed. There are no obvious fixing points. Will I have to remove hub/bearing
assembly to get to fixings. If yes is it straight forward or should I get hold of a Cortina Haynes manual.
Hope someone can help.
John.
Working on a CVH 1.8 engined Locost. Hoping to use as much as possible of Sierra donor. £210 left.
scutter
posted on 22/4/03 at 07:28 AM |
John,
You will have to remove the hub assembly as the disc cover is held on by three M8 bolts. most people use these holes to mount the front wing
stays.
A haynes would be advantageous when it comes to rebuilding the hubs, as it contains all the needed torque figures.
All the best Dan.
Jon Ison
posted on 22/4/03 at 06:05 PM |
and dont bother refitting the shroud.....
John
posted on 22/4/03 at 06:37 PM |
Thanks Dan & Jon for advice.
John.
