smart51
posted on 7/6/06 at 11:19 AM |
Stiff steering problem
My steering seems to have gone a bit stiff. I have to put a bit more effort into turning in before it moves. There is also less self steerin such
that on gentle curves, it stays in whatever position you leave it and so have to turn back to straight ahead.
I have a shortened sierra rack with a quick rack fitted. It has been on the road for 6 months.
The car steers OK from lock to lock. Nothing is loose or visibly rubbing. What are likely causes of this extra friction?
Marcus
posted on 7/6/06 at 11:22 AM |
Is it a Sierra column, check the plastic bush at the lower end, they wear.
Marcus
Because kits are for girls!!
smart51
posted on 7/6/06 at 11:29 AM |
Thanks for the suggestion. The plastic bush at the joint between the upper and lower columns is fine, I've checked this.
posted on 7/6/06 at 11:37 AM |
have you jacked the front end of the car and stun the wheel?
check the balljoints - they can seize and then shear off (happened to a 101 that left an intereesting groove from the nato hitch in the road!
google for LR 101)
Finally with front of the ground, rremove the ball jpoints and try the steering, that will locate the problem to the rack or column.
then undo the UJ on the column, that will show problem in rack or column if problem persists.
Locost82
posted on 7/6/06 at 11:39 AM |
Divide and Conquer
I suggest you jack the front up and disconnect the steering column. Move the steering wheel and if the wheel is still stiff, the problem is in the
column. If not, the problem is in the rack etc.
Divide the steering up into small parts as required to see what is stiff.
[Edited on 7/6/06 by Locost82]
Markp
posted on 7/6/06 at 04:56 PM |
the steering universal joint could be starting to seize.
Mark
scutter
posted on 7/6/06 at 05:30 PM |
I have this problem at the mo, it's caused by not clamping the upper column mount at 90 deg to the main shaft,
it's a winter fix for me as the dash, scuttle and upper mount need to be removed.
i'd try releasing the clamp and see if it gets any better.
ATB Dan.
smart51
posted on 7/6/06 at 06:48 PM |
It turns out that the plastic bearing thing was the big cause which was a surprise as it isn't tight. I greased it and took it out round the
block. It is quite a lot better with less "sticktion" on initial turn in and more self centering. Though better, it still has quite some
friction, though I guess this may be normal for a quickrack and small wheel.
