sebastiaan
| posted on 7/6/06 at 07:11 PM |
Sierra ABS front hubs. Picture wanted!
Guys,
Has one of you got a pic of a Sierra front upright / brake assembly with ABS sensor they'd like to share with me?
Since my engine upgrade i've been thinking that traction control is a nice function to have, and the code for the Megasquirt i'm using is
already written.
Rear wheel speed isn't a problem, as i've got an electronic sender for my speedo already.
Also, were there sierra's with solid front discs and ABS?
Sebastiaan
natehall
| posted on 7/6/06 at 08:15 PM |
i dont have any pics - but if you were to get the hubs - they are identical to the normal sierra ones - apart from the sensor coming out of the front
of them and the cable running into the car
no sierra was solid front and ABS afaik
however it does not matter - as you can use your current calipers and discs on the abs hubs and should be able to do it all without bleeding the
brakes (just dont disturb the brake lines- the calipers just bolt off whilst attached to the spacer - and bolt em back on to the abs hub
If it aint broke, uprate it
if it is broke, uprate it
http://www.modders-uk.co.uk
sebastiaan
| posted on 8/6/06 at 05:02 PM |
So the sensor ring is on the hub, and not on the brake disc? Sounds like this might just work!
Anyone got a picture? I'd like to see where the sensor is, as i can't really work out where the sensor will be....
natehall
| posted on 8/6/06 at 05:25 PM |
i can get you a picture of mine on a sierra tommorrow if you want
and yes - the sensor is on the hub and not the disc
sebastiaan
| posted on 8/6/06 at 06:05 PM |
Yes please!
