Author: Subject: finished my hoist
robertst
posted on 8/6/06 at 11:25 AM Reply With Quote
finished my hoist
almost looks as the ones they sell, except without the pneumatic arm.
i really like it! it looks like michael schumacher's F1
check out the welding on this thing!! like a pro and bear in mind, i'm using an arc welder! (3rd pic...)
finished hoist
finished hoist
looky looky
finished hoist 2
finished hoist 2
the weld
professional weld
professional weld
thanks to everybody for their support when designing this thing.
[Edited on 8/6/06 by robertst]
Tom
joneh
posted on 8/6/06 at 11:30 AM Reply With Quote
Nice! That reminds me - Makro are doing (or were) that electric hoist for £29.99 + VAT.
Marcus
posted on 8/6/06 at 11:35 AM Reply With Quote
Cool job.
Might have been tempted to put castors on the rear legs to aid manoeverability (is that spelled right?)
Marcus
Because kits are for girls!!
robertst
posted on 8/6/06 at 12:04 PM Reply With Quote
bah.. dont really need to move it sideways. just using it to pull the engine out from the front. the hoist is to lift it slightly ajar.
Tom
cassidym
posted on 8/6/06 at 12:17 PM Reply With Quote
Goody! I'd like to copy your design - how about some specs?
SeaBass
posted on 8/6/06 at 12:28 PM Reply With Quote
What sort of Safe Working Load are you intending on this thing??
jambojeef
posted on 8/6/06 at 12:43 PM Reply With Quote
I think James is thinking the same thing that I am....
Without knowing the grade or wall thickness of the steel used for its contruction - especially in the upright section, I would say you have 2 fairly stiff looking triangles joined by a rather unsupported upright section.
I would be very careful what you use it for and how much load you intend it to take - especially since it has an electric winch and you may exert large dynamic loads during the starting and stopping of the motor which will be difficult to control.
Im not being an arse about it - I think its really nicely finished but it pays to be safe
Geoff
robertst
posted on 8/6/06 at 02:00 PM Reply With Quote
thanks for your concern
i have made extra care in setting up the proper welding for perfect weld penetration and also on the triangulation. the tubes are all 3mm thick and some tubes are 40mmx40 and others are 50x50
i intend to use it to support the engine and gearbox combo when taking it out of the donor car. the engine is a pinto with a type nine box. i guess they both weigh close to 150-170 kgs.
as a test drive, a friend and i hung from it and it bent, but no cracking or stress sounds. he weighs 80kgs and i weigh 65 so i guess that gets close to the real stuff.
Tom
cassidym
posted on 8/6/06 at 02:06 PM Reply With Quote
Thank you for the specs.
robertst
posted on 8/6/06 at 03:42 PM Reply With Quote
check my photo archive, i have the designs there.
Tom
Liam
posted on 8/6/06 at 04:50 PM Reply With Quote
But did you and your friend hang on it and try and bounce up and down? Repeatedly? That would be a more realistic test. How much did it bend by the way? Hope it works but be careful.
Liam
owelly
posted on 8/6/06 at 05:11 PM Reply With Quote
My money is on the legs bending. Just around the area where your cross members are welded across.
BTW, the welding doesn't look to clever. Can you run a cap weld over it to get rid of the undercut and burn out the slag?
http://www.ppcmag.co.uk
MikeR
posted on 8/6/06 at 05:44 PM Reply With Quote
what about just putting the rear part of the bracing on (ie from the bit out the back to the bracing coming up from the floor).
Also, there is no sideways bracing. Probably isn't needed but my crane has some gussests welded onto the side of the upright and that looks like its 75x75mm (guess) and 3 or 4mm thick min. (guess).
(i've got the machine mart, folding 1 tonne one - biggest issue i have is that the front legs won't fit under the car )
caber
posted on 8/6/06 at 09:27 PM Reply With Quote
How about a 4mm steel wire fronm the bit that sticks out the back down to the back cross member with a turnbuckle to tensionit? the vertical should then be in compression with much less of a tendency to bend?
Caber
robertst
posted on 9/6/06 at 08:16 PM Reply With Quote
problem with that is that in the event of failure, the wire can decapitate you.
Tom
caber
posted on 9/6/06 at 09:52 PM Reply With Quote
Hmmm. decapitated or crushed under falling engine, your choice of a way to go
Caber
posted on 9/6/06 at 09:56 PM Reply With Quote
simple, do a test lift first. Its easy to look and it and work out the weakest point, and then work out how to make that point stronger. Id replace the wire with a small tube, no stretch then. Maybe a 25mm tube? Can only help.
robertst
posted on 10/6/06 at 12:37 AM Reply With Quote
yeah. i will try it out to see if it lifts the front of the car, only a couple of inches though as the front weighs over 500kgs so i dont wanna over-stress the hoist.
i guess the human test (i.e: 130 kgs hanging from the hoist) is enough proof
Caber
well, i suppose a big part of the safety instructions of the electric winch, the haynes manual, and many other books say "keep clear of the lifting area". hence the 2 metre wired remote control.
i would be seriously gutted though if it were to fail and the engine drops onto the floor and destroys the sump and whatnot and makes a bloody mess of my garage
Tom
