| posted on 12/6/06 at 06:49 AM |
The more I think about it ....
... the less happy I am about the way the front brake hoses were fitted (not by me!)
The problem arises becaise the hole for the grommet through which the hose passes is slightly to big meaning the that grommet is not as tight a fit as
it could be and can be poked out quite easily. That would result the hose rubbing on the side of the panel.
inside view showing the bracket and short lenght of hose going vertically before turning through 90 degrees.
Image deleted by owner
and outside view; hose leaving the side panel. (actually you can see the string the hose is putting on the grommet at the top)
Looking for ideas how to solve this - is there a special grommet available?
I reckon the only fix is make a bracket so the hose end is mounted horizontally, not vertically so it does no go through 90 degress, that would
require a short length of brake tube, but I think the rubber hose would then be too long (100 mm), in which case I'd probably go for custom
length hoses
Ideas as always welcome.
[Edited on 12/6/06 by 02GF74]
bimbleuk
| posted on 12/6/06 at 08:44 AM |
Maybe simply move the hole further down so the hose enters the car horizontally. The let the cable loop back up inside the car body, assuming theres
room.
| posted on 12/6/06 at 09:13 AM |
Braided Hoses are the answer...
You can then secure the pipe to the side panel using the bulkhead fitting. Easier to remove etc etc etc....
| posted on 12/6/06 at 09:38 AM |
Turn the bracket through 90* so the pipe exits straight through the bodywork if you have enough pipe spare.
| posted on 12/6/06 at 02:24 PM |
I am considering t his as my solution as it avoids any movement between hose and bodywork; will the panel, between 1 and 1.5 mm thick attached with
self tappers be ok?
(would need sorter hoses I'm sure).
