Chippy
| posted on 12/6/06 at 10:45 PM |
Ford LSD overhaul.
Hi, can anyone tell me if its feasable to carry out an overhaul on the above. I have quite a bit of backlash in the CW and pinion, can this be shimmed
out? Also the LSD part is pretty weak, quite easy to turn, I understand this should be somewhere in the 70lb pressure range. Are any overhaul kits
available. Any help gratefuly recieved. Thanks Chippy
tks
| posted on 13/6/06 at 08:49 AM |
mhhh
there is some pdf on the net.
the link should be on this forum.
so if you search you should find.
the procedure was as original ford.
Tks
