Author: Subject: Fiat 125 Rear Axle
guzmanp
posted on 14/6/06 at 11:42 AM Reply With Quote
Fiat 125 Rear Axle
I'm planning the construction of my Locost with a Fiat 125 donor car. I'm double checking the dimension and the rear axle of the fiat is 50.7" between brake drums, is this meassure enough for the book chasis? and for the 442 ??
locost_bryan
posted on 15/6/06 at 03:04 AM Reply With Quote
Should be ok for a book chassis - Estfield use the Lada clone.
Someone here is building with a 125, so you should be ok.
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
procomp
posted on 15/6/06 at 06:50 AM Reply With Quote
Hi i think as said it's the same as the lada one . Whitch we use on book chassis. For a wider version there is the lada 4x4 niva whitch is 100mm wider.
cheers matt
