Author: Subject: Cortina hubs/ sierra brakes?
sg_frost
Builder
Posts 104
Registered 6/11/02
Member Is Offline
Photo Archive Go!
Building: Haynes roaster in college with students, gulp!
posted on 24/4/03 at 08:48 PM Reply With Quote
Can bigger brakes from a sierra be fitted to cortina hubs, especially the big 4x4 brakes?
bob
posted on 24/4/03 at 09:19 PM Reply With Quote
austin princess 4 pots will go an,bit big and heavy but they work a treat.
scutter
posted on 25/4/03 at 03:33 PM Reply With Quote
You can fit Capri discs and brakes to the cortina hubs, if you want vented discs, take a look in the front susp pics in my archive.
Dan.
eddie
posted on 29/4/03 at 12:29 AM Reply With Quote
i see where you are going, i was about to post somthing like this myself, the sierra vented disks would be desirable if they will fit onto the cortina uprights
Fast Westie
posted on 29/4/03 at 08:02 AM Reply With Quote
You do not need vented disks on a Locost.
Now having got that clear. If you feel the need to go for 4-pot calipers, stick with the alloy ones, the pricess and Sierra ones are pretty heavy
The car in front is a Westfield
kiwirex
posted on 29/4/03 at 10:22 PM Reply With Quote
Fast Westie says:
What about the heavier engines (e.g. R V8 )?
Anyone completed a V8 locost?
Any brake fade with solid discs ?
- Greg H
- Greg H
Fast Westie
posted on 30/4/03 at 01:33 PM Reply With Quote
Most V8 Westfie1ds use solid disks. I race my 200bhp Westfie1d with solid disks, Wilwood calipers with no brake fade. My 160bhp road Westfie1d uses solid disks, M16 calipers, Mintex M1144 pads and does not fade the brakes
