Winston Todge
| posted on 21/6/06 at 06:58 AM |
Sierra diff flange retaining nut?
Just curious as to whether people replace these when rebuilding? And loctite?
It's the nut that sits on top of the flange and seems to have a small nyloc section to it. Would you get it from a Ford main dealer? Cost ish?
Torque figures?
Thanks,
Chris.
indykid
| posted on 21/6/06 at 08:34 AM |
on the front flange that bolts to the prop?
if so, don't touch it unless you plan to strip the diff down or change the pinion seal. between that and the crush spacer, it sets the pinion
bearing preload. if you do undo it, count the turns it was undone by exactly and retighten it to that amount. if not, you'll need a rolling
torque gauge to reset the preload.
hth
tom
Peter M
| posted on 21/6/06 at 08:54 AM |
You can replace pinion oil seal/nut on sierra type diff no need to worry about preload as the pinion flange nut does not effect pinion pre load see
link below.
changing pinion oil seal
my previous cars
my westfield build
Winston Todge
| posted on 21/6/06 at 11:08 AM |
Thanks for that Pete!
I have heard a lot recently that the preload is set by this nut and was at a loss to see how it could.
That Haynes outake seems to put that to rest.
Just curious as to whether any standard nyloc would do the job or whether the Ford one is required? Thread Pitch??
Thanks again guys,
Chris.
[Edited on 21-6-06 by Winston Todge]
Winston Todge
| posted on 21/6/06 at 11:47 AM |
Apparently Ford don't stock this anymore!
But measurements are M16 x 1.5 so fingers crossed I can find somewhere local.
Chris.
Donners90
| posted on 21/6/06 at 02:59 PM |
If it's part 28 on the pic below then Ford should still stock them. Ask for FINIS # 6122453. Listed as £1.70inc VAT
