omega 24 v6
posted on 1/7/06 at 12:23 PM |
Pedal ratios
I've done a search and no definative answers so here goes.
Does a brake pedal ratio of 3 to 1 work? or will I need to rethink?
Seems dificult to get any more as from the floor to the ball of your foot is only around 230mm so for 5 to 1 it'd need to be nearer 400mm
long
Unless I make a raised area in the footwell to raise my feet up.
nitram38
| posted on 1/7/06 at 12:30 PM |
Try this: CLICKY
JB
| posted on 1/7/06 at 12:36 PM |
Pedal Ratio
With floor mounted pedals as you say the size of your foot has a large bearing on the design.
So I got the best pedal ratio I could within the space allowed then chose the MC bores that would give a reasonable foot force. I had to consider,
vehicle weight, tyre dia, disc dia etc etc. Fred Phuns Brake Handbook helped.
John
RazMan
| posted on 1/7/06 at 01:54 PM |
I'm working with floor mounted pedals which give about 3:1 so I certainly hope they work! In theory it will just mean that pedal pressure will
have to be 'assertive'
Raz
omega 24 v6
| posted on 2/7/06 at 08:37 AM |
Cheers mark      I'knew you'd pass comment. The thing that's annoying me is that it looks so bloody basic and simple on the
car. So why the fcuk can I just not get my head round it. I have started making the brackets etc though. Hope you've had a good holiday. I
ain't done much here though too busy working and shopping for my holiday gear. (Why cant I go in my boiler suit and jeans??)
Gav
| posted on 2/7/06 at 10:12 AM |
The GTS pedals have a ratio of 5:1 iirc
