brynhamlet
| posted on 2/7/06 at 06:23 AM |
Brake pipes & live axles
How do poeple fasten the brake pipes onto a live axle with drum brakes (MK2 escort) They are currently fastened with tie-wraps which I'm sure
would be a SVA fail. I thought of Stainless Steel tie-wraps but don't know were to get them from
caber
| posted on 2/7/06 at 06:28 AM |
usually tabs of thin sheet welded to axle and folded over pipes.
Caber
Humbug
| posted on 2/7/06 at 07:28 AM |
I used large jubilee clips (about 4" diameter from B&Q), undid them then reconnected them round the axle and the pipes. I slipped a piece of
slit fuel hose over the pipes.
907
| posted on 2/7/06 at 07:39 AM |
Or,
drill a small hole in a jubilee clip, a c/s screw through the hole from the inside, and fit to axle.
A "p" clip, washer & nut on the protruding thread.
Paul G
John Bonnett
| posted on 2/7/06 at 07:55 AM |
I would follow the manufacturer on this one and do as has been said. Make some taps from 18swg mild steel and weld to the axle casing. It will look
professional and as it was meant to be.
John
jollygreengiant
| posted on 2/7/06 at 10:35 AM |
Ok I know its of post but.
Nice Oscar 907.
scutter
| posted on 2/7/06 at 03:21 PM |
Drilled and tapped when the casing was bare, pipe fitted with rubber lined P clips.
ATB Dan.
  axle finally finished
owelly
| posted on 2/7/06 at 11:45 PM |
Scutter, how have you sealed the threads to stop oil leaks or am I missreading your photo?
http://www.ppcmag.co.uk
907
| posted on 3/7/06 at 12:03 AM |
Nice Oscar 907.
He's names Wellard. Been through a few fights that one.
Brought him home on the tank of my Yamaha. Loved it. Got his fins down an' everything.
Paul G
| posted on 3/7/06 at 12:08 AM |
Is he in a tank on his own? My brother in law had one and it ate everything else in there with it
907
| posted on 3/7/06 at 12:26 AM |
No, five of them and a pleck.
At the moment the room light is off, the tank light is on and the window is open.
Big commotion every now and then when one of them catches a moth.
Paul G
scutter
| posted on 3/7/06 at 10:39 AM |
Owelly, It's just the way the pictures taken, the threads are an inch above the fill line, doesn't need sealing yet .
ATB Dan.
brynhamlet
| posted on 4/7/06 at 08:45 PM |
Seeing as the car is all but finished jubilee clips with p-clips fastened to them seems to be the best solution. Will report after SVA which with a
following wind may only be a month away
brynhamlet
