Author: Subject: Propshaft reassembly
chockymonster
posted on 2/7/06 at 02:31 PM Reply With Quote
I split my prop to help me get it into the tunnel whi'ch I've now managed.
I've lined the marks up so that I know it's back together the way it was but I can't get the damn thing back together properly.
I'm guessing it should be a tight fit to get it back together but I can only get the nose of the front part of the prop about 3/4 of the way through the UJ and that has been a hard battle.
How have others that have split their prop got it back together?
mark chandler
posted on 2/7/06 at 03:26 PM Reply With Quote
It sounds like its not aligned properly.
When you split it, looking in the female end there is a spline missing, on the male two splines are joined at the very front.
Get this one spline out then with a struggle it will go together, it sounds like you are at that point.
Regards Mark
