dutchsuperseven
| posted on 29/4/03 at 06:04 PM |
Siėrra rear axle width
What's the width of the rear trailing arms on a Siėrra axle in the normal loaded position. I mean the distance (outside) between the flanges on
which the bearing carriers are bolted.
Sex, drugs and Supersevens
Liam
| posted on 29/4/03 at 08:57 PM |
Well I make it 1500 from disc to disc (outside edge) which would make it...measures up assembled disc and hub...about 1395 between the outside of the
trailing arms (or inside of the hub carriers if you like).
Give or take a couple of mm.
Liam
jcduroc
| posted on 30/4/03 at 10:08 PM |
Sierra rear axle
Liam
I measured 1530 mm face to face of the drums (1600 Sierra), ie, mounting surface fro the wheels.
Joćo
