Author: Subject: Sierra / Granada Diff mounting
jollygreengiant
posted on 13/7/06 at 09:07 PM Reply With Quote
Well things are progressing here at Higham Towers, got my diff fitted today.
So I thought I'd pass on my little dodge for fitting the lower mounting, you know, where the Looooonnng bolt is supposed to go.
I didn't fancy using a long stud and I didn't fancy modifying the head of bolts, so I lay underneath and looked and thought. Then it struck me, the slot underneath is about the right width, why not slip a lock nut in and let the sides hold the nut. Tried it but the nut wouldn't quite fit on the bolt. So I very carefully removed/rounded three adjacent corners from the nut.
It worked a treat, the slot is just the right width to hold a lock nut and the bolts fit in from the outside.
I hope this helps some of you.
Tinks
posted on 14/7/06 at 11:56 AM Reply With Quote
I just used 4 cap head bolts they fit in a treat
Simon
posted on 14/7/06 at 08:58 PM Reply With Quote
JGG
I ground down the heads of the bolts instead.
About 3 1/2 years ago
Simon
jollygreengiant
posted on 15/7/06 at 10:43 AM Reply With Quote
Originally posted by Simon
JGG
Simon
Yep thought about that but just seemed a lot more work opposed to the nut option.
chockymonster
posted on 15/7/06 at 12:48 PM Reply With Quote
Helicoil the bottom holes
