ditchlewis
| posted on 29/7/06 at 05:46 PM |
Mk Top front wishbones
I've had my friendly ferrari mechanic around today (brother inlaw) whilst looking at the front suspension he pointed out that the upper
wishbones are very very different. is this a manufactureing problem or are they susposed to be a long long way out?
what are your experiences???
Ditch
graememk
| posted on 29/7/06 at 05:48 PM |
in what way do you mean, do you have a pix.
jacko
| posted on 29/7/06 at 06:04 PM |
Hi what do Ferrari machanics know about proper cars
Jacko
ch1ll1
| posted on 29/7/06 at 06:17 PM |
what way do you mean different?
| posted on 29/7/06 at 06:18 PM |
Have you put them both the same way up?
ditchlewis
| posted on 29/7/06 at 07:30 PM |
the section shows the treaded tube is at different angles
whilst the plan shows that on one side the wishbone follows the lower whilst on the other it is way out, thus giving very different geometry on each
side
graememk
| posted on 29/7/06 at 07:59 PM |
i'm going to have a look at mine in the morning now
| posted on 29/7/06 at 08:30 PM |
quote: Originally posted by chris mason
Could be wrong but it seems like you may have 2 of the same wishbones
as you look from the top and rear the rear arm of the top whishbone should be almost at 90 degree to the chassis while the front arm tapers backwards
quite a bit. although your diagrams aren't too accurate it seems that your left wishbone could be the same as your right one.
Chris
I'd tend to agree with this comment but the threaded part should be equal to each other. Return them IIWY
jacko
| posted on 29/7/06 at 08:35 PM |
Time to ring MK they dont look right to me Jacko
ditchlewis
| posted on 30/7/06 at 07:32 AM |
Many Thanks..
it's what i thought , as they are clearly left and right, but they have very different radii, one must have been made wrong.
a phone call to MK on Monday     this will set back my plans to have the car finished before the summers over
car was almost complete now it comming apart again..
Ditch
