Author: Subject: English axle propshaft bolts
posted on 3/8/06 at 11:16 AM Reply With Quote
I have English axle - mk2 esort - and the prop shaft flange it bolted to the diff flange using 4 bolts - the diff flange is threaded for this.
Is this how it should be?
I was expecting a bolt/nut type arrangement? (Land rover-esque)
Is it possible that the bolts should have been screwed into the diff flange, the prop flange going over the bolts with nuts to hold it all in place?
nib1980
posted on 3/8/06 at 11:28 AM Reply With Quote
thats the same as mine, and works Ok for me
posted on 3/8/06 at 11:40 AM Reply With Quote
It's just 4 bolts into the diff flange - nothing else required.
Loctite or other thread-lock compound is strongly recommended, just in case.
posted on 3/8/06 at 11:44 AM Reply With Quote
Yes on both types of flange - some MK2 used MK1 style small flanges with 5/16" UNF threads.
