Author: Subject: Sierra Driveshaft length ? ABS & non-ABS
tomblyth
posted on 10/8/06 at 06:39 PM Reply With Quote
I have LoBo drive shafts from the 2L DOHC sierra fitted to 4x4 LSD , and the off side shaft seams a bit long, The ? is are all sierra shafts the same ( I know the off side is longer)
eg. Is sierra lobo O/S with ABS the same length as without ABS
Stu16v
posted on 10/8/06 at 08:43 PM Reply With Quote
There are two different length shafts (for both sides) available, with approximately 1/4inch difference between the two types. However, alledgedly they are interchangable...
tomblyth
posted on 12/8/06 at 07:08 AM Reply With Quote
Shart length
Then I have the long ones and they don't fit my Indy
Liam
posted on 12/8/06 at 11:53 AM Reply With Quote
Shouldn't be any length difference between ABS and non ABS. ABS shafts just have a toothed ring added.
There's so much plunge in the CVs (a good 50mm per shaft) that slight differences in length shouldn't matter. Afaik no manufacturer specifies that particular ABS/estate/4x4/etc etc shafts can or can't be used based on any length difference. All i know is that the ABS tothed ring has to be machined off for ABS shafts to fit MK Indy rear uprights.
Liam
