Author: Subject: F27 lower wishbone bushes
gregf27
posted on 21/8/06 at 07:58 PM Reply With Quote
Managed to get hold of some stronger lower wishbones for my F27,after my little mishap when an original one snapped on the move!
but they came with no bushes unfortunately !!
does anybody know where I can get either polybushes or metalastic type bushes from? am only after 4.
metal sleeve is 38mm long , inside diameter is 27mm?
there seems to be many different sizes out there!! , none of which I can match up to mine!!
and yes I did a search!
regards,
Greg
Rudy
posted on 21/8/06 at 08:22 PM Reply With Quote
mine is the same dimensions.
I buy it from Tel: (+44) 1895 460033
Fax: (+44) 1895 520095
sales@powerflex.co.uk
www.powerflex.co.uk
I am happy about their service and product: I had goods after two days I ordered it!!!! in ITALY!!!
Sorry for my English
Kissy
posted on 22/8/06 at 05:32 AM Reply With Quote
Get some turned from Nylatron or Nylon if you can - it's a bit firmer than even the hard poly.
gregf27
posted on 23/8/06 at 03:04 PM Reply With Quote
Can anyone recommend any more places?
am struggling to find anywhere!!
Greg
gregf27
posted on 2/9/06 at 07:22 PM Reply With Quote
I guess not then
does anyone know if MNR / GTS/ luego do the bushes?, and what size dimensions the "standard " ones are??
Greg
locoboy
posted on 2/9/06 at 11:39 PM Reply With Quote
MNR will turn you what ever you need Greg.
Just give them a call - nice guys too boot.
Locoboy
TangoMan
posted on 3/9/06 at 02:14 PM Reply With Quote
I am suprised someone that one of the powerflex can't supply what you need. It may be that you need to get bushes with larger centre holes and then fit tophats in to sixe down to your bolt size. I think they also do the tophats in various sizes.
Failing that why not modify the bones and go for rose joints. Less flex and easily adjustable. That's what I have!!
[Edited on 3/9/06 by TangoMan]
Summer's here!!!!
gregf27
posted on 6/9/06 at 05:33 PM Reply With Quote
have managed to track down the original bush supplier to when Steve Porter owned F27, new bushes £4.50 each!!!
Happy man!!!
thanks for the replies guys
Greg
