RichardK
| posted on 25/8/06 at 04:21 PM |
3 degrees positive camber on the rears
Look like I've dropped a b*ll*ck and positioned the upper brackets a bit too close to the edge and I now have 3 degrees of positive camber on my
rears, I don't suppose this is normal as the book says zero.
Why does stuff like this only happen when I decide that everything is right and so fully weld
Note to self, measure twice weld once
Rich
wilkingj
| posted on 25/8/06 at 04:52 PM |
Sounds too much the wrong way. I though 0-1 degree negative (tops leaning in) would be fine. 3 positive is out.
Sounds like a job for Mr Angy Grinder with those nice 1mm Slotting discs with some careful and steady hands.
Whats the consensus on cutting off the "ears" of the bracket and welding a new bracket on top of the old one, it would only be about 1-2mm
higher, or cutting the bracket off completely and replacing with one in the correct position?
Doesnt sound too much of a problem.
I wouldnt want any Positive Camber let alone 3 degrees worth. Not good for handling on corners.
Best Regards
Geoff
http://www.v8viento.co.uk
| posted on 25/8/06 at 06:22 PM |
Cut the ends off the top wishbones and redo them, probably be easier than hacking the chassis.
| posted on 25/8/06 at 08:38 PM |
Slot holes in bracket, weld washers over slots in correct location. Only good if the amount of adjustment needed isn't much though.
RichardK
| posted on 25/8/06 at 09:29 PM |
Thanks chaps, I think I will try to get the old ones off and reposition them. Wish me luck
Regards
Rich
Liam
| posted on 29/8/06 at 06:45 PM |
Probably too late now, but i just saw a pic of your rear wishbones on another thread. Can't you adjust your rear camber by turning in the rod
ends?
Liam
