Author: Subject: tyre question again......
posted on 2/9/06 at 11:14 AM Reply With Quote
.... this time pressure.
what should I be using (front & rear) in my tyres: 195/50 R15, alloy wheels, form 27, 1300 crossoflow, english axle (dunno waht my weight is) for use on the road.
ta.
NS Dev
posted on 2/9/06 at 11:16 AM Reply With Quote
heh heh!
not an easy question to answer, depends on many things, weight of car, type or tyre (not size but exact construction, compound etc)
As a starting point, you won't go far wrong at 18-20psi (cold pressure) and work from there.
TangoMan
posted on 2/9/06 at 11:21 AM Reply With Quote
Formula 27 with live axle and pinto. I have settled at 18psi.
I tried higher and lower and settled at this as the best option although a couple of psi either way didn't make a vast difference.
Summer's here!!!!
posted on 2/9/06 at 11:26 AM Reply With Quote
I'll try with 20 psi.
for self centring, read people shove in mopre air in the front - 30 psi? will that mean nasty handling on the road?
mookaloid
posted on 2/9/06 at 12:09 PM Reply With Quote
22 psi in my indy is enough to give nasty handling, I run 16-18 at the front 18- 20 at the rear on 195/50 R15s
Cheers Mark
