Author: Subject: Willwood powerlites and cooper slip
Gav
posted on 4/9/06 at 09:18 PM Reply With Quote
When ever ive changed pads in the past ive always found that they were previously fitted with a dollop of copper slip on the back.
Would doing this with the powerlites be advisable seeing as they dont have dust seals
or will it be ok as long as i make sure i clean the pistons before pushing them back in?
RazMan
posted on 4/9/06 at 09:32 PM Reply With Quote
The copper grease is usually put on the back of the pads to help stop squealing. It should be ok on your Wilwood calipers - as you say, just clean the piston before you push them back in
[Edited on 4-9-06 by RazMan]
Raz
C10CoryM
posted on 5/9/06 at 12:02 AM Reply With Quote
Copperslip antiseize is used to help prevent squealing. It is a petroleum product and rubber hates it. We use a high temp silicone lubricant at work instead. You need that stuff for caliper pins and any rubber/metal contact anyhow.
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
