gregf27
| posted on 8/9/06 at 07:45 PM |
Use of loctite type product for wishbone metalastik bushes?
I have finally managed to obtain some metalastic bushes for my replacement front lower wishbones on the F27,
(long story that involved a crash!)
it has been recommended to me to use a loctite type product when fitting them to the wishbone sleeves,
any body else done this ?, and what product would you recommend??
cheers,
Greg
JB
| posted on 8/9/06 at 07:57 PM |
Retainer
You want a retainer such as bearing retainer. There are different grades, unfortunatly I only know 638 which is high strength and would need heat to
get out the bush.
John
gregf27
| posted on 8/9/06 at 08:19 PM |
Cheers John,
where would I get some from? and how much is it ?
atb
Greg
indykid
| posted on 8/9/06 at 11:48 PM |
281 is bearing fit compound if that helps. red, and sets hard
tom
JB
| posted on 9/9/06 at 06:03 AM |
Loctite Source
Cromwell Tools sell it. They have branchs all over the country. Otherwise your local fastener supplier or tool shop.
Ebay may also have some.
John
Kissy
| posted on 9/9/06 at 12:51 PM |
IIRC the bushes are an interference fit (mine needed pressing) so you should not need loctite. If you want to make it easier to press them out next
time use some Copperslip grease. Better still turn some bushes out of Nylon or Nylatron.
