Author: Subject: Small brakefluid leak
dr-fastlane
posted on 16/9/06 at 05:55 PM Reply With Quote
Hello,
Today I saw that the bleed screw of one of the front brake callipers (Teves) leaks. It seems to me that the brakefluid comes between the bleedscrew and calliper body.
Has someone experienced this same problem before? And how can I solve this?
Greets Roy.
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
t.j.
posted on 16/9/06 at 06:08 PM Reply With Quote
Originally posted by dr-fastlane
Hello,
Greets Roy.
I will tell you for your stuf i wanna have
But i don't have any idea.
Could you take a new bleedscrew?
ch1ll1
posted on 16/9/06 at 06:41 PM Reply With Quote
silly question
but have you tried to nip it up ?
if that don't work tried a new bleed nipple
if the fails the new caliper
stevec
posted on 16/9/06 at 07:01 PM Reply With Quote
It is possible that the caliper is cracked because someone before you overtightened the bleed nipple. The force of the taper at the bottom of the screw is capable of splitting the casting. Hope I am wrong.
[Edited on 16/9/06 by stevec]
RazMan
posted on 16/9/06 at 10:02 PM Reply With Quote
How about a little Locktite Threadseal on the nipple thread?
Raz
posted on 17/9/06 at 07:02 AM Reply With Quote
try a new nipple
dr-fastlane
posted on 17/9/06 at 08:30 AM Reply With Quote
The caliper and bleedscrew are new. For this reason I find it strange. Today I will look if the screw is not overtightened, or that I perhaps cracked the caliperbody or bleedscrew. And fit an new bleedscrew on Monday.
To all thank, now I know where to look at. I will let you know how it has gone.
Greets Roy
dr-fastlane
posted on 17/9/06 at 02:10 PM Reply With Quote
I've found it, i think. Perhaps i might have tightened the bleeding screw to hard. The tip of the screw has some markings on it.
The caliper casting seems oke.
I'll replaced the screw with an old one i had and now it seems to be alright.
Thanks for helping.
T.J. I thought that you would say that
[Edited on 17/9/06 by dr-fastlane] Rescued attachment bleedscrew.JPG
