Nick Davison
| posted on 19/5/03 at 09:05 AM |
Hand Brake
What make of hand brake cable will fit a Capris live axle, other than Capris of course?
Nick
dutchsuperseven
| posted on 19/5/03 at 09:02 PM |
Nick
I used Fiėsta mk1/2 cables on a Cortina mk4 axle.
Greetingz, Rob.
Sex, drugs and Supersevens
Mark Allanson
| posted on 19/5/03 at 09:55 PM |
Whats wrong with using the capri handbrake cable?
gjn200
posted on 19/5/03 at 10:18 PM |
Sorry,could'nt resist
Can't help myself here sorry, Great feet!!!!!!!
<- Me!
| posted on 20/5/03 at 09:11 AM |
I did same as Mark but I shortened the cable and put the bar on the axle to the other side as it was close to the panhard rod.
Nick Davison
| posted on 20/5/03 at 07:05 PM |
The Capris cable would be ideal but I don't have enough room behind the axle due to a large fuel tank and mounting it in any other place than
original would prevent it working correctly.
The Fiesta one sounds as though it may do Rob. How was it for length and what type of brake plate connections has the cortina axle used?
Nick
scutter
| posted on 20/5/03 at 07:30 PM |
I know it sounds like an original idea, but what about an allergro, as per the book. available from halfords £6 per side.
Dan
dutchsuperseven
| posted on 20/5/03 at 08:38 PM |
Nick
Well, i must admit i changed a lot. I swapped the backplates from left to right, so the cables exit at the rear.(had to swap the brake-shoes also.
This way the length of the cable won't get in your way.
The cortina axle's cilinders are very different to the capri's(sliding cilinder?).
But , it works well.
Greetingzz, Rob.
VinceGledhill
| posted on 17/11/03 at 05:11 PM |
I was going to ask about the hand brake cable then came across this thread after doing a search.
Does this capri item connect to the sierra hand brake lever OK?
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
| posted on 17/11/03 at 05:38 PM |
I modified the handbrake by welding a piece of bar to it and drilling a hole for the cable in that. I shortened the cable with a "U"
clamp.
yours, Pete.
Mark Allanson
| posted on 17/11/03 at 09:31 PM |
I left my handbrake level unmodified, I just need to make steel 'bullet' with crossdrilled threaded holes to crimp the cable.
VinceGledhill
| posted on 18/11/03 at 09:25 AM |
Just looked at my Capri Live axle and I cannot see how I can use the Capri cable. RU1 and RU2 are in the way.
Can't see how I've got my ride height that high that it is no good.
I've built a book chassis as per Martin Keenan's instructions and made it an inch taller. Thinking about it logically, I should have more
clearence at this point than less.
Do the back plates on the axle come off? Are the bolts even if they do? If so I could move the backplates round a quarter of a turn to make the
cable fit.
Regards
Vince Gledhill
Mark Allanson
| posted on 18/11/03 at 07:41 PM |
Vince, have you got a picture?, I cannot see how RU's can be anywhere near the handbrake cable, my cable runs along the centreline of the axle,
the backplate has a nylon lined guide for the rod to slide through.
I am going to raise the chassis end of my panhard rod to give it a bit more clearance though.
VinceGledhill
| posted on 18/11/03 at 11:38 PM |
I'll take pictures and post them in the moring.
Regards
Vince Gledhill
VinceGledhill
| posted on 19/11/03 at 03:22 PM |
You can see from the picture that the lever goes in a downward movement.
I have decided to order the book Alegro ones and will move the backplates through 90 degrees so that the levers come out just above and to the left of
the push rod connecting bracket.
Regards
Vince Gledhill
